Welcome to the Irish Mini Owners Club Forum. Celebrating 30 years of the Irish Mini Owners Club, 60 years of the Mini, 55 years of the Moke and 50 years of the Clubman
carburetor issue
Moderators: irishminis, spud1979, The Marcos Graveyard, Moderators
Adam-Dublin
What Minis have you?: 1974 Austin Mini
carburetor issue
Post by Adam-Dublin » Thu Apr 06, 2017 11:22 am
Hi all,
New to the club & just joined the forum. Hi!
I have a quick question for you & looking for advice.
My mini is 1974 Austin & 998cc.
When I start the car it idles perfectly but as the car warms up the idle goes up too.
It gets to the point that i nearly don't need to touch the accelerator to drive away at lights!
Any ideas out there?
Adam
Re: carburetor issue
Post by Billy » Thu Apr 06, 2017 1:50 pm
Hi Adam and welcome to the forum,
Have you topped up the oil in the carb dashpot?
Adam-Dublin
Post by Adam-Dublin » Fri Apr 07, 2017 12:38 pm
Thanks for that Billy. I'll give that a go at the weekend & hope it does the trick!
Post by woody » Fri Apr 07, 2017 5:30 pm
Welcome to the club Adam.
You haven't mentioned the choke.
When the engine is cold it should require choke to bring the idle up to the right speed and than less choke as the engine heats up.If your car is idling ok cold without choke it will increase speed as the engine heats up.
The other thing would be an air leak on the inlet manifold that would expand as the engine heated up.
Adam-Dublin
Post by Adam-Dublin » Thu Apr 13, 2017 10:17 pm
Hi Woody. Thanks for reply. I topped up the pot and no joy.
You might be onto something with the choke. When cold I only use a tiny bit of choke for maybe 2 seconds and it then runs perfectly. If I pull any more choke it kills it instead of bringing revs up?
Post by keith » Mon Apr 17, 2017 8:10 pm
Hi Adam,
if you don't get it sorted i could pop round or you could come over to me and we'd have a look at it.
I'm in Deansgrange,
K.
Adam-Dublin
Post by Adam-Dublin » Wed Apr 19, 2017 7:14 pm
Sorted it! In the end it was the tension spring on the throttle arm. James in Minifix threw another spring in and good to go. Thanks all for help and advice and hopefully bump into you soon. Adam
