1983 Mini City
Re: 1983 Mini City
Post by woody » Sun Dec 13, 2020 10:55 am
every bit helps in the fight against the Irish climate. We'll have to drive our minis a lot more to get the temperature up
colinf1
Whats your location?: Dundalk
Re: 1983 Mini City
Post by colinf1 » Sun Dec 13, 2020 11:52 am
Does that mean I have to stop driving my Nissan Leaf??
Re: 1983 Mini City
Post by woody » Mon Dec 14, 2020 9:18 am
Good donor car for electric mini.
colinf1
Re: 1983 Mini City
Post by colinf1 » Wed Dec 16, 2020 11:02 pm
Had a look at the front shock absorber brackets today, they are extremely rusted on back sides, so I've drawn up replacements that I've had laser cut and folded.
1st job was to salvage the pins, cut them out and cleaned off the remaining bracket...
Then offered them up to new bracket and welded into place, no picture of the finished article yet as I have to linish back the welds and some splatter...
Got my minispares order delivered today, 3 big boxes 😄😄
Unpacked it in the kitchen, soon ran out of floor space..🤣
Nice new heritage inner wing, arrived in a big box by itself!
Hopefully I can fit everything inside the shell of the car, plus I've a tonne of cardboard packaging to try and fit in my recycling bin!
colinf1
Re: 1983 Mini City
Post by colinf1 » Tue Dec 22, 2020 5:28 pm
Reamed out the bush with the help of the 3d printed guide and pilot...
New bearing pressed in with the help of M16 threaded bar....but looked around and noticed the plastic sleeve...doh! Forgot to put it in...
Tried to tap out the bearing gently but wasn't successful, pinched a bit of the casing and caught one of the needles.
You can see one of the needles pushed outwards against the casing..
Took the bearing out of the repair kit for the opposite side to at least get one side finished.
All assembled and touched up any paint chips...
colinf1
Re: 1983 Mini City
Post by colinf1 » Fri Jan 01, 2021 5:27 pm
Got a few hours at the mini today, it was a toss up between cleaning the shed or doing something on the car...
Decided to start taking off the front end, drilled out all the spot welds on the drivers wing to avoid any further damage to the inner wing. Passenger side was easier as I just cut through the inner wing.
I didn't even need to do much to get passenger A panel off, literally fell off after I removed wing.
Inner wing was very difficult to remove, thanks to the dodgy repair that had been done. A patch was weld to the inner and outer A posts, then was losing light so couldn't see where spot welds where along floor panel, so nipped it off an inch or so into the inner wing.
A bit of cleaning up to do on the cross member, next I'm planning on removing the scuttle panel to get better access to the top of the inner wings and closing panels
ctwomey
What Minis have you?: I owned a 1977 Mini 850 when I was in my late teens. I owned a 1986 Mini Chelsea that I imported from the UK. Also owned a MG Metro that was bored out to 1293. Restoring a 1981 Dublin Mini City.
Re: 1983 Mini City
Post by ctwomey » Fri Jan 01, 2021 7:20 pm
Just a quick question, did the shot blasting of the shell remove the seam sealer everywhere ?
Just seen your latest post. Great work today.
colinf1
Re: 1983 Mini City
Post by colinf1 » Fri Jan 01, 2021 8:12 pm
I think it got rid of the vast majority of it, I'll double check in a few places tomorrow.
Thanks for the complement, gives me good motivation to keep at it!
It is a lot of work, but best to do it right rather than a bodge job like what's been done before.
I think I need to get some bracing into the shell before going any further into the door step or floor
colinf1
Re: 1983 Mini City
Post by colinf1 » Mon Jan 04, 2021 5:04 pm
Had a look at this earlier, yes the blasting got rid of the seam sealer everywhere.
ctwomey
Re: 1983 Mini City
Post by ctwomey » Mon Jan 04, 2021 9:12 pm
That's great Colin. It's an absolute pain to remove. So I can just concentrate on the repair areas for now.
colinf1
Re: 1983 Mini City
Post by colinf1 » Fri Jan 08, 2021 6:05 pm
Picked up the subframes that got reblasted, but it's too cold to take them from car to shed, so they can stay in the car for now..
ctwomey
Re: 1983 Mini City
Post by ctwomey » Fri Jan 08, 2021 8:11 pm
Oh it’s cold alright. Even in my garage using an air tool I can last about 1 hour. Ordered one of those propane blast heaters to warm the space up.
colinf1
Re: 1983 Mini City
Post by colinf1 » Sat Jan 09, 2021 3:18 pm
Had planned on trying to get scuttle panel off today, bit ended up trying to sort the condensation in my attic, pretty wet up there even though all vents are clear.
Stuck a dehumidifier up there see if that helps, think it may be caused by immersion venting into the cold water tank so I've disabled the timer for now.
Moved all my mini parts to the south facing side of attic, it's perfectly dry!
colinf1
Re: 1983 Mini City
Post by colinf1 » Sun Jan 10, 2021 3:56 pm
Tried cleaning the original headliner and rear covering panels, both covered in red overspray and contact adhesive on the back sides.
No joy, contact adhesive will come off with white spirit but the staining that has gone through the preferrated material and the overspray is just too much to try and save it, time for the bin unfortunately.
Even it rods are a bit rusty, need a good cleaning but salvageable.
colinf1
Re: 1983 Mini City
Post by colinf1 » Sun Jan 10, 2021 5:24 pm
Some pictures of headliner and rear covering panels...
These almost came up as good as new...
Someone was a bit heavy handed with the glue...
Overspray, glue weeping through and rust staining...
colinf1
Re: 1983 Mini City
Post by colinf1 » Sat Jan 16, 2021 8:52 pm
Picked up a mig welder in the week, a Swp 150, wasn't a great start when I couldn't get the wire loaded due to a damaged liner, so back to the shop to get it sorted.
Have it set up ready to go, so hopefully get something welded tomorrow, think I'll start on the parcel shelf speaker hole repair, should be a simple square piece to weld in and dress it off - real practice rather than wasting wire and gas on test pieces...
colinf1
Re: 1983 Mini City
Post by colinf1 » Sun Jan 17, 2021 4:29 pm
Well, that didn't go as planned.... pigeon poo and no penetration...
Back to the bench with test pieces to figure out how to weld...even wasted a full bottle of gas....😭
ctwomey
Re: 1983 Mini City
Post by ctwomey » Sun Jan 17, 2021 5:00 pm
Are you using one of those disposable bottles? If so get yourself a 10L or 20L bottle from stargas instead.
Remember with MIG the current is controlled by wire speed and arch length by the voltage switches.
Also switch to 0.6 if you are not already using it. And practice, practice, practice. All those old panels are great for testing.
Butt welding is going to require lower settings than plug welding.
colinf1
Re: 1983 Mini City
Post by colinf1 » Sat Jan 23, 2021 6:00 pm
Some more practice with welder today, decided to try and join the front end together again. Wasn't overly concerned about it lining up properly, just concentrating on good strong welds. Was also using gasless wire, wasn't too bad to use, just a bit fumey
Will turn it into a garden feature, maybe a bench or a planter...
Cleaned up around the inner LH wing and A post, getting the remaining pieces ground off. A post needs a small patch but is good otherwise, door jam panel also looks ok once cleaned. There was a lot of brazing around front part of the doorstep panel, would it have been like that from factory?
Wire brushed around the number a bit more today and revealed it was 8 not 6. So 470383 - suggests it's 03/1983 build date of shell. 47 part is a mystery, maybe production line or operator number?
