Engine doesn't turn over
Moderators: irishminis, spud1979, The Marcos Graveyard, admin, woody, Moderators
Post by DaveC » Mon Apr 01, 2019 9:39 pm
1992 Mini City 1000
The battery is fully charged.
Turn the ignition key to start, the oil light and ignition light come on, but then nothing happens. The oil and ignition lights stay on full.
Trying the same with the headlights on, the lights stay on full. I am guessing power isn't getting to the starting motor.
Any suggestions for what the problem is and how I get going again?
Re: Engine doesn't turn over
Post by Billy » Mon Apr 01, 2019 10:41 pm
Dave, it could be the starter solenoid? Is there a click when you turn the key?
If No, It's a faulty solenoid. If yes, It's probably the starter.
PROJECT X
Post by The Marcos Graveyard » Tue Apr 02, 2019 8:41 am
Hit the solenoid on top of the starter motor a few smacks with a hammer, might encourage it a bit.
Post by Billy » Tue Apr 02, 2019 9:44 am
And failing that, take a screwdriver and arc between the two connections of the solenoid. If that works, it's the solenoid is definitely the problem.
There probably won't be many tractor supplies outlets near you Dave, though I may be wrong, but they're handy for supplying the old-style push-button solenoids.
Post by DaveC » Tue Apr 02, 2019 1:18 pm
Thanks for the suggestions, I will have a look later.
There is no click when you turn the key.
I was wondering if it might be the relay for the starter?
Post by Billy » Tue Apr 02, 2019 2:22 pm
This is the type I use on the older Minis cos even if it fails, you can get started by just pushing the button. It can also be very handy for setting points etc.
There's probably cheaper than this locally;
http://www.retroclassiccarparts.com/pus ... 76464-copy
Post by woody » Tue Apr 02, 2019 9:54 pm
I think '92 is a pre-engaged starter with the solenoid on the motor.
Also your car will have a starter relay between the ignition switch and solenoid.I think its on the inner wing beside the servo.
The wire from the ignition switch to relay also has a bullet connector behind the heater where the inhibitor would be connected in an automatic car, this connection needs to be closed.
It is easy for a small amount of dirt to jam the solenoid but it is easy to split in two and clean.
Post by DaveC » Wed Apr 03, 2019 1:10 pm
It was dark when I looked at this last night so I gave the solenoid a few taps with a hammer, pulled out the relay and cleaned up the contacts, and it fired up straight away. Thanks all for your comments
Post by woody » Wed Apr 03, 2019 8:32 pm
Getting it ready for MTM?
Post by Billy » Thu Apr 04, 2019 4:11 pm
Or bring it down to the Bog Run this Sunday.
