Welcome to the Irish Mini Owners Club Forum. To aid the prevention of the spread of the Covid - 19 Virus. With the greatest of respect for our Members, families and general public. We have taken the conscious decision to postpone all runs, meets and events until further notice
Problems Starting mk3
Moderators: irishminis, spud1979, The Marcos Graveyard, Moderators
kindalen
Post by kindalen » Wed Apr 22, 2020 9:59 am
Hi,
I am trying to start a 1973 car that has sat in a shed for about 7/8 years :roll:
I have drained old fuel and put in 5l of fresh petrol.
I hooked up a battery and lights work, but nothing happens when I turn the key except the alternator sparks so I unplugged it.
I think, in my very limited experience, that there may be a problem with the earth straps. I have a new set on order.
I also think the starter may be stuck, have tried rocking car in gear.
Any suggestions? Try a push start?? Use jump leads direct to starter?
Thanks.
Re: Problems Starting mk3
Post by woody » Wed Apr 22, 2020 10:25 am
Did the altenator spark when you turned the key to the ignition position or the start (spring) porition.
Did you get any dashboard lights with the ignition on?
Did the motor crank over in the start position?
kindalen
Post by kindalen » Wed Apr 22, 2020 10:37 am
Hi, not sure on alternator. Will check later.
Yes, dashboard lights came on with the ignition on.
Motor did not crank to the start position.
My, cheap and nasty Lidl, battery tester tells me my battery is in decent condition.
Thanks.
Post by woody » Wed Apr 22, 2020 11:17 am
Most likely the solenoid , with the key in the start position try tapping it. You should hear it clicking on and off
kindalen
Post by kindalen » Wed Apr 22, 2020 11:29 am
Thanks very much, will give it a try.
kindalen
Post by kindalen » Thu Apr 23, 2020 6:59 pm
Tried the above this evening, heard no clicking. I forgot to check dashboard lights, but headlights and interior light were on. I will stick the battery on a trickle charge just to be sure it has enough juice.
I re-connected the alternator, and no sparks today.
Post by woody » Thu Apr 23, 2020 10:35 pm
If the solinoid is knackered you can short the terminals with a big spanner (expect a big spark) and the motor should turn.
kindalen
Post by kindalen » Fri Apr 24, 2020 7:11 am
Thanks, have the battery out charging. Could I stick jump lead from positive direct to solenoid, and ground other jump lead to engine block? Would that have the same effect? Thanks for all your help.
Post by Billy » Fri Apr 24, 2020 10:17 am
Even easier. Just cross the two positive & negative on the solenoid itself with a screwdriver.
I usually fit a push button solenoid to my minis.
kindalen
Post by kindalen » Fri Apr 24, 2020 10:51 am
Great thanks guys. Will update ye on how I get on. :?
kindalen
Post by kindalen » Fri Apr 24, 2020 7:00 pm
Hi, didn't get the mini started, but am delighted I did get it cranking. Will hopefully get time to have a go again tomorrow.
Thanks.
kindalen
Post by kindalen » Sun May 03, 2020 11:33 pm
Update.
Replaced the faulty solenoid today. Car still cranking but not starting. Didn't even get to check spark, noticed clutch is really stuck. Engine bay is quite rusty in general.
Any advice on freeing clutch?
Should I throw in new spark plugs, leads and condenser and points? Already put in a new rotor arm.
Post by Billy » Mon May 04, 2020 8:52 am
Re clutch: once you've got car running, turn off engine then put it into first. Keep your foot on the clutch. Turn on ignition. The car will jump forward but keep that foot on the clutch. Usually the clutch will free after a bit. Don't attempt any of this without working brakes and plenty of outdoor space.
kindalen
Post by kindalen » Mon May 04, 2020 10:13 am
Thanks so much for the advice. I am crippled with a lack of knowledge and talent! Next time I get to car I'll check for a good spark. After that I presume I'll check for petrol getting to the carb.
Thanks Guys.
kindalen
Post by kindalen » Mon May 04, 2020 3:35 pm
Today I checked for spark, go no spark at all. Took off cap and leads and cleaned cap and checked leads for cracks etc. points seemed a little corroded, gave them a quick clean in situ and put all back together.
After this I got a weak spark on all leads. Cranked over a good few times and got a weak cough trying to start once or twice.
What should I try next?
Thanks.
Post by woody » Mon May 04, 2020 4:21 pm
If you got a cough your nearly there( or its got the virus ) . put fresh petrol in the carb float chamber and make sure theres oil in the dashpot. Then you say the clutch is locked do you mean the arm won't move at all?
kindalen
Post by kindalen » Mon May 04, 2020 4:42 pm
Hi, Clutch pedal is stuck, and in the arm is stuck also, no movement. Ye, hopefully nearly there. Will try the oil and petrol. Do I need a specific dashpot oil? Was using easy start today instead of petrol in the carb, is that ok or is petrol better?
Thanks.
Post by woody » Tue May 05, 2020 10:45 am
You'll probably find that easy start is giving you the cough but petrol is too old to keep it running. Unleaded petrol loses a lot of its octane rating after a year lying in the tank.
To check if the clutch slave cylinder is seized remove the dust cover and push back the piston with a narrow screwdriver, if it moves than press the pedal again to bring it back out.If it is seized remove it to see if the clutch arm moves freely. If it doesn't move you can try penetrating oil but personally I would remove the wok and dismantle and clean everything.
kindalen
Post by kindalen » Wed May 06, 2020 10:18 pm
Update.
Thanks to advice from here got car started today. Added a bit of oil to dashpot and petrol to carb and after a while got it going. Lots of crappy smoke, never made me so happy!
Clutch still stuck, used screw driver to moved it slightly, and tried starting in first and second to no avail. Didn't have time to do much more today. Will remove spring and check movement next time I get to look at it.
I just want to say thanks to the support from here, car wouldn't be started at all without the help here.
Post by woody » Wed May 06, 2020 10:22 pm
Glad to help. The starting the car in gear is only for when the arm is moving but the plate is stuck to the flywheel. Get the arm moving freely first.
kindalen
Post by kindalen » Thu May 07, 2020 11:39 am
Forgot to mention that when the car is off I can put it in gear. However when I started it it would not go into gear.
Post by Billy » Thu May 07, 2020 12:18 pm
That's because the clutch isn't working.
kindalen
Post by kindalen » Fri May 08, 2020 12:59 pm
Clutch slave was seized alright. New one ordered.
kindalen
Post by kindalen » Fri May 15, 2020 3:15 pm
Quick update. Am still waiting on new clutch slave. Got a few minutes today and removed the operating lever. When I took it out I was able to rotate the throw-out stop fully and to move it in and out. However when I cleaned and re-installed the operating lever it hardly moves?? Is this normal?
Thanks.
Post by woody » Fri May 15, 2020 3:24 pm
The clutch shaft does not move a lot during normal operation and its movement is limited by the throw out stop and the return stop. Removing the clutch lever arm removed the return stop.
