mini cooper s 2000 overheating
Terrybrennan76
Whats your location?: Cork
What Minis have you?: Classic Mini Cooper s 2000 reg
Bmw Mini cooper 2008
Modifications: none
Post by Terrybrennan76 » Mon Jul 20, 2020 1:20 pm
After a period of storage i have started using my mini Cooper S Again 00 G 23
After a short while the expansion tank starts bubbling .
i have checked the following
thermostat replaced
new coolant
Head Gasket oil clear no evidence of a damaged or blown gasket
fan cutting it at temperature but not colling it down sufficiently
any ideas what next ?
Terry
Re: mini cooper s 2000 overheating
Post by woody » Mon Jul 20, 2020 3:05 pm
As the car has been sitting up the first thing to check is that the stat is opening.
MPi engines run a normal temperature around 100 deg. C so it is important that the cooling system holds pressure as water boils at a higher temperature under pressure. Is there any steam coming out. MPi expansion bottles are known to crack where the hoses join the tank.
Post by Billy » Mon Jul 20, 2020 3:07 pm
Terry,
What thermostat are you using? Mpi's run hotter than carb Minis. I had overheating problems with my old 98 mpi but it was a common problem with a sensor which was activating the fan. There was a factory upgrade which cured it. The other possibility is that your 20-year-old rad has silted up.
Post by Billy » Mon Jul 20, 2020 3:08 pm
Woody beat me to it.
Post by Billy » Mon Jul 20, 2020 3:10 pm
The other known issue is the quality of the expansion tank tops. As Woody says, the system needs to be pressurised to work properly.
Terrybrennan76
Modifications: none
Post by Terrybrennan76 » Tue Jul 21, 2020 12:15 pm
Thanks guys
rad checked and ok
upgraded stat and its working
no evidence of blown gasket
the hunt goes on .
hope ye are all well during these terrible times
Terry
jpmcc
Whats your location?: Derry
What Minis have you?: 2000 Rover Cooper Sport
2006 R52 Cooper S John Cooper Works
Post by jpmcc » Thu Jul 23, 2020 10:33 am
Try replacing the coolant header tank cap, I replaced mine with one from a 2006 Mini Cooper S.
Instantly stopped any heating issues on my 2000 Sportspack 8)
Terrybrennan76
Modifications: none
Post by Terrybrennan76 » Mon Jul 27, 2020 2:22 pm
thanks guys im taking a few days off this week and will get stuck in to it
DOUGAL
Post by DOUGAL » Tue Jul 28, 2020 11:13 pm
Check the cooling fan speed. It may be cutting in OK but may not be turning fast enough. I had this problem with one turned out to be bad earth to fan. 9
DOUGAL
Mark B
Whats your location?: Glenageary, Co. Dublin.Ireland
What Minis have you?: 2000 Cooper Sport
Post by Mark B » Tue Aug 18, 2020 1:54 pm
I had a problem with overheating on my 2000 Cooper Sport, the coolant was flowing through the rad but not being cooled , a new rad solved the problem but I tried everything else before replacing the rad.
